Car wouldn't shut down when accelerating hard...
  • Thread starter Thread starter wifehatesit
  • Start date Start date May 7, 2007
W
wifehatesit
21
  • May 7, 2007
Had a scary thing happen the other day, just got done changing a blown head gasket, and torque converter. I put the motor in, buttoned it all up and took it for a blast... when I mashed the throttle, it continued accelerating (or at least pulling hard) after I let off the gas. It all happened so fast I couldnt diagnose whether the gas pedal was stuck down or not.
Normal, I'd think binding linkage or serious vacuum leak.. but the car is a race car, and and there's not much in the way of vacuum hoses.. I did snug down the carburetor a bit more just to be safe. The thing that tells me its probably not a vacuum leak is the car idles perfect, and doesn't hunt at all. I just replaced the base plate on my carb with a Pro-form aluminum baseplate because my stock holley base plate had a cracked bolt-down ear. I'm wondering if the baseplate bound up...
At idle, the rpms drop quickly with no hang up or delay at all... this is another reason I don't think its a vacuum leak..
I'm going to buy a new throttle return spring to be safe...
any other ideas?
BigHairyMonkey
411
Houston (Bellaire) TX
May 7, 2007
  • May 7, 2007
your throttle cable could be binding up, or your pedal is physically getting stuck on something, carpet, etc
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 7, 2007
  • May 7, 2007
Try playing with the throttle with the engine not running. Have a helper press the accelerator pedal while you watch the throttle butterflies and linkage.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
