Carb advice
  • Thread starter Thread starter Paul619
  • Start date Start date Nov 6, 2004
P
Paul619
83
  • Nov 6, 2004
I am having a heck of a time tuning my carb. It is a 600cfm Vac Sec. I finally have the plugs looking like I want them and it does pretty good in the low end. I have the main jets and a s stage power valve right about where i want them now it is time to get the secondairies going. I have a flat spot around 3000rpm and I cant seem to get rid of it. I am running a smaller check ball in the vac sec. and it has the bare metal spring in it. it feels like they are not opening fast enough. I have reamed out the sec. jets on the metering plate and that made a difference (holley and their no adjustment for the secondaires ha) definitly pulls hard about 4 grand up to 5500 but if I had the extra 1000 revs out of the mid range I think it would fel alot better. no matter how you are driving it does it at the same spot too. From a dead stop or rolling even worse in 3rd gear though trying to pull through the revs. and that is right about the 60- 80 range and just doesnt want to move i hae the timing set at 36-37degres total(dont know what the initial is right now but i bet is it close since i hae no low end problems.) I have trick flow heads and tri ys weiend manifold msd roller rockers and a cam with .540 total valve lift and a duration of 240 if you have any ideas or if anyone in san diego can help me out I wil definitly be gracous
tia
Paul
rbohm
6,698
550
204
tucson,az
Nov 6, 2004
  • Nov 6, 2004
use a lighter secondary spring to get the secondaries opening quicker, and a heavier spring to slow them down.
D
D.Hearne
11,730
south louisiana
Nov 6, 2004
  • Nov 6, 2004
You need a bigger carb. I'd also remove that check valve. I don't recall ever seeing one on my old 600. If you've got a manual trans, consider stepping up to about a 700 cfm carb. With your setup, it ought to pull to 7 grand at least.
P
Paul619
83
  • Nov 6, 2004
i dont think i want to try to have my car spin 7 grand on stock rods still havent gone through the bottom end
P
Paul619
83
  • Nov 6, 2004
well i went to the white spring and it made it worse I guess that it is getting too much fuel in the mid range and it just bogs so i guess holly was right in what they wrote i guess now i will try the stiffer spring
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
