Carb Convertion Help
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jun 25, 2012
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 25, 2012
  • Jun 25, 2012
Well i know where its going to go, but IDC im looking for links and info on what all to delete from my 91 car to switch it to carb the correct way. Im in the middle of a build and want to switch from EFI to carb. I looked and didnt find anything about it. Dont want to do a hack job looking to delete whatever wiring the proper way and possibly selling some of it? Thanksguys! peace
john
ratio411
3,870
73
109
Pensacola FL
Jun 25, 2012
  • Jun 25, 2012
Well, if you went to a carb and DS2 distributor, you could take out everything EFI intact.
That way a sale would be much more likely since the wires won't be cobbled up and you won't need the ECM.
(DS2= Ford electronic ignition used roughly 1974 to 1980, DuraSpark 2)
rd
3,316
63
109
Ocean Springs MS
Jun 26, 2012
  • Jun 26, 2012
Do a search here. Its been done bezillions of times. Ignition goes to Duraspark. Hardest part seems getting a lower pressure fuel pump for the carb, throttle linkage, etc.
ratio411
3,870
73
109
Pensacola FL
Jun 30, 2012
  • Jun 30, 2012
It would seem to me that you might be able to get an inline adjustable regulator, with return line capability, and use the stock lines and pump. You would have to be able to get down to around 7psi max. That would have most of your fuel going back through the return line when running.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jul 1, 2012
  • Jul 1, 2012
I did it on my 86. I took out the factory fuel lines and ran new 3/8 aluminum tubing. I removed the in tank fuel pump and installed a pick-up. I mounted an electric fuel pump at the rear of my car. ( these pumps seem to like to push rather then pull fuel. Mounted a regulator up at front of engine and plumped it all in. Wasn't that hard. Took the harness apart. removed computer and associated harness. I installed an entire MSD ignition system. It just takes time.
R
redwings06
33
  • Jul 3, 2012
I converted to carb and left the stock fuel pump, just installed an inline regulator to keep the psi lowered for the carb
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
