Carb cost????
ok i don't have all that much money and im getting a 358w short block and i just got a pair of original 1969 Ford 351W heads These heads have been ported, have screw in studs and guide plates,and roller rockers with posi-locks. The intake valves are 194s and the exhaust are 160s. Stainless exhaust valves and hard seats High performance valve springs to see pic of heads go to my garage. now i need to no what cam intake and carb to get i was thanking edelbrock air gap intake road demon 625 to 750cfm and edelbrock rpm cam and lifters or rollin thunder cam and roller lifters but i thank that will eat to much gas what do you guys thank i should do?
I'd start talking to USAF46270. What he has is probably the exact same as I have on my 351C. Bought that carb for the P.O. when I thought he was going to be my future son-in-law. For 35 bucks, its a steal (EDIT: Like about $200 off) - even if you have to install the "Power-Valve Backfire Safety". All things (cam,porting,rockers, etc) being equal; 2V Cleveland heads flow better than any factory-stock W heads, so my .030-overbored 357 Cleveland has the potential to suck more air than your Windsor. The 600 CFM Holley is highly recommended for that block; unless you're going with lotsa valve lift and planning on keeping the RPM's above 3500.
BTW how did you get 358? Did you go .035 over? :scratch:
