carb gurus....need advice
  • Thread starter Thread starter dragnazz5.0
  • Start date Start date Nov 14, 2006
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Nov 14, 2006
  • Nov 14, 2006
alright, the combo is a 306, slightly ported stock heads, tfs 1 cam, 1.7 rockers, air gap intake and edelbrock 600 carb. the carb has the 8 in/hg step up springs, .101 main jets, 7047 metering rods and the idle mixture screws are about 2 turns out. now my problem....its got a tip in stumble/hesistation. ive tried backing the idle screws out more but it doesnt help. ive changed jets and rods just in case they would help also but nothing. i dont know where to go from here. the car has 16 in/hg for vacuum and idles fine and drives great except for this problem. i guess really the only thing left is a vacuum leak or rebuild the carb or get a new one. someone give me some opinions or advice...thanks fellas
Modular2v
3,222
23
99
oklahoma
Nov 14, 2006
  • Nov 14, 2006
if you have been tinkering with it that much and nothing had improved it chances are the whole thing needs a overhaulin or just get a new one
bt15
129
Oahu
Nov 14, 2006
  • Nov 14, 2006
Is the problem on your initial tip-in or are you talking about during secondary actuation? You probably mean initial tip-in based on what I've gathered. That being the case, what size shooter is your primary? Have you changed it from stock? If not, you may need slightly more. For example, if your stock shooter was a 31 and you have made mods to your car, you may need a 35 or more. There's also the Edelbrock Tech line if you are so inclined. I'm running a Demon carb now, but the Edelbrock guys were pretty helpful when I was running an Edelbrock.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 14, 2006
  • Nov 14, 2006
yeah its a initial tip in problem. everything on the carb is factory so i dont know what the primary squirters are.
edit:i just realized i left something out that i had found today. the motor was fully warmed up when i was working on it today but i noticed when i got the air horn off there were bubbles coming out of the primary jets....not huge bubbles but just small little bubbles coming out for maybe 10 seconds after i got the cover off.....is that normal or does that mean there is something leaking somewhere?
Modular2v
3,222
23
99
oklahoma
Nov 14, 2006
  • Nov 14, 2006
have you checked the power valve? metering block gasket?
feifong
319
mesa
Nov 14, 2006
  • Nov 14, 2006
i have the same 306 but with afr heads, tfs1 go with a bigger carb 670 sa should help a little. Its the intake its made for higher rpms thats where youre hesitation might be. Go with a weiand or upgrade to bigger carb and fuel pump. just my opinion
89lxcoupe
207
harlan,ky
Nov 14, 2006
  • Nov 14, 2006
well i've always run a holley 650 dp at the biggest 750, on most 302 setups they like about a 1 inch - 2 inch spacer between the carb and intake to get the tip in stumble to go away, that always fixed my problem with the tip in stumble. but also going up with the squirter a couple sizes will help ! just my experience.......
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 15, 2006
  • Nov 15, 2006
ill have to try that spacer idea. other wise im gonna see if my boss will let me buy his holley 650 double pumper
Modular2v
3,222
23
99
oklahoma
Nov 15, 2006
  • Nov 15, 2006
a dp is the way to go anyway
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 15, 2006
#10
  • Nov 15, 2006
  • #10
does anyone know anything about the bubbles coming out of the jets? im just wondering if this is normal or if there is something wrong
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Nov 15, 2006
#11
  • Nov 15, 2006
  • #11
Fuel percolation,try putting a heat insulating spacer under the carb.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Nov 15, 2006
#12
  • Nov 15, 2006
  • #12
thats kind of what i was thinking but couldnt think of the word. im gonna try to put a spacer on it and see what happens
F
carb vs cam help needed
  • forango
  • May 2, 2024
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2025
forango
F
L
Engine Need help 90 mustang carbed 5.0
  • logonhappy
  • May 28, 2021
4K
Fox 5.0 Mustang Tech Sep 3, 2022
Flyboy60
F
D
Carb Spitting
  • daer0
  • May 16, 2021
3K
Classic Mustang Specific Tech Jul 28, 2021
7991LXnSHO
Engine Carbed 5.0 swapped run like chit.
  • Smurfstang88
  • Jan 13, 2021
  • 2 3
7K
Fox 5.0 Mustang Tech Jan 22, 2021
a91what
R
Progress Thread At the end of my tether!
  • Ricktheninja
  • Apr 19, 2020
2K
1965 - 1973 Classic Mustangs -General/Talk- May 11, 2020
Jaha95
J
