Carb Guys... Removing Electric Choke?
  • Thread starter Thread starter 93project
  • Start date Start date Oct 2, 2012
93project
549
52
38
El Paso, tx
Oct 2, 2012
  • Oct 2, 2012
Anyone pull the electric choke off their fox? I'm tired of the high idle , especially since my car doesn't see cold, rainy, weather. Its a garage car, and the idle sux when started cold. Can I just pull it off? Keep the valve open?
88LX5.Oh
1,442
204
94
Arkansas
Oct 2, 2012
  • Oct 2, 2012
Since it's electric, why don't you just disconnect it?
StangGT1995
Banned
Oct 1, 2012
20
Chicagoland
Oct 2, 2012
  • Oct 2, 2012
Put the EFI back on it, like Ford intended?
93project
549
52
38
El Paso, tx
Oct 3, 2012
  • Oct 3, 2012
The valve in the choke horn stays shut when disconnected. Idles even higher. As for putting efi back on.... that's not gonna happen. My efi harness was fubar. But, I did my Carb conversion the RIGHT way. Its not a halfa$$ job. I just screwed up in getting an electric choke
HotFox
1,051
653
164
SE Michigan
Oct 3, 2012
  • Oct 3, 2012
My quick fuel 750 does not even have a choke . Starts just fine in the weather that I drive the car in .
Scott
CarMichael Angelo
8,909
234
Birmingham, al
Oct 3, 2012
  • Oct 3, 2012
Fix the choke. You have the ability to " lean" the choke setting, therefore speeding up the pull off time it's in fast idle mode.
Or, you can always convert it back to EFI...I'm sure that would be waaay easier than just turning the 3 screws to allow the choke housing to spin.
While you're converting it back to EFI, may as well take the opportunity to rebuild that engine while your at it, since converting it back to EFI makes so much sense.
Reactions: 93project
93project
549
52
38
El Paso, tx
Oct 3, 2012
  • Oct 3, 2012
Lol I was waiting for a comment like this from you! Alas, um keeping the Carb... I'll adjust it tonight after work.. see if I can get down quicker...
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Oct 3, 2012
  • Oct 3, 2012
To answer the question, yes you can just remove it entirely, including the choke butterfly if you really want. But, you should be able to adjust it so it doesn't idle crazy high on cold start up.
CarMichael Angelo
8,909
234
Birmingham, al
Oct 3, 2012
  • Oct 3, 2012
It's like this. Lets do a comparison shall we?
You, and Frankie fuel injection are sitting side by side in the parking lot of the apt complex you both live in. It's 6:00 am, 27 degrees out and you're both late for work. You have removed your choke. You swat the pedal twice, and fire that sucker up, it starts right off, but because there is no choke, it dies as soon as you let it idle. To keep it from doing that, all you have to do is hold it at 1200 rpm for one minute. From there on, you kinda have baby the throttle, because it wants to bog because the engine temp hasn't reached 100 degrees yet.
Frankie fuel injection gets in his car and turns the key. The car starts instantly, and he backs up and leaves the lot in a hurry( he is late as well) only because he doesn't have a carb that had the choke removed, he isn't still sitting in the lot,... Holding the throttle at 1200 rpm so the motor won't die.
Guess who gets to work first?
Fix the choke. Removing it will be the first step towards a bad carb experience.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Oct 3, 2012
#10
  • Oct 3, 2012
  • #10
Your math is all wrong. My car will be warm enough a mile into the drive that it'll idle just fine, but it won't matter because i'll be driving that SOB at WOT blowing Frankie fuel injection's doors off, and i'll get to work before him because he's a tree hugging hippie who won't accelerate too hard because he's worried about his carbon footprint.
93project
549
52
38
El Paso, tx
Oct 3, 2012
#11
  • Oct 3, 2012
  • #11
I get your point, but my car will never be driven in weather like that. Its a garage queen that sees days in the 70-100 degree range. And it only goes from my house( no apartment thank you), to work... 15 minutes away. So, I will adjust the idle ... for now.. but I really don't need a choke
Boosted92LX
5,721
4,244
224
Oct 3, 2012
#12
  • Oct 3, 2012
  • #12
Always an entertaining response from David.
ChuckStyles
Banned
Sep 29, 2012
51
San Diego, CA
Oct 3, 2012
#13
  • Oct 3, 2012
  • #13
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
