carb jetting
67matang
38
rose creek mn
i have a 67 mustang with a 351 w heres what is done to it..
twisted wedge heads
roller rockers
extreme energy 274h cam
holley 750
weiand stealth
headers with 2.5" pipe and flowmaster 40s
8.8 rearend with 3.73's
c-4 with shiftkit
my problem is that i changed my 8" air filter to a 14" k&n and now at 3500 + rpms it hesitates and revs up really slow..could this be the jets in teh carb? i changed it back to my 8" and the problem went away.
thanks
Have you checked to make sure the new air cleaner is not somehow interfering with the linkage on the secondaries....or even the primaries? I would check for interference first as a change in air cleaner should not have that much affect on the jetting of a carb, it could have some but I doubt it would be as significant as you indicate.
67matang said:
well nothing is interfering..i have a drop base to clear the hood and nothing is hitting..
Once, while trying to figure out why my engine wouldn't idle, I noticed that when I had the base of the air cleaner off (I also have a drop base with 3" tall filter) the engine wouldn't idle correctly (internal carb problem), but when I put the base back on, the idle would pick up significantly. I also made sure none of the linkage was hanging up or caught somehow, but it wasn't. I think the design of the base increases velocity of air flow into the carb. I think I remember reading something about this phenomenum many years ago in a magazine.
67matang said:
when i put the drop base on with the filter then the lid there is only like 1" or less between the lid and the base so could that be causing the problem?
I guess I'm having trouble picturing your setup. Is it an open element type air cleaner, because the K&N filter should be about 3" tall, isn't it? If you only have 1" between the lid and the base with the filter in it, how does that compare to your original air cleaner housing and filter? It really sounds like an air flow issue.
the air filter is just a round 14" like most carbed engines. i looked at it this morning and with the lid on i have a little less than 1" inch between the lid and the base..the old one has about 2.5" (however tall the air filter is) the K&N filter is about 2.5" tall.
