carb setup questions...
  • Thread starter Thread starter Paulywalnuts446
  • Start date Start date Jun 13, 2005
P
Paulywalnuts446
84
  • Jun 13, 2005
so i coverted over to carb from fuel injection and have a couple of questions. what type of throttle cable do i use? can i use a stock one from a fuel injected stang? if not where can i get one for a carb setup, is there any holes on the block or head that i have to plug?
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Jun 13, 2005
  • Jun 13, 2005
No you cant, the geometry is all wrong. It will only open the throttle blades 60-70% when floored. Get the lokar throttle cable. $25
You should make sure all the vacuum ports on the carb are sealed tight cause the carbs are all about vacuum. Any leaks and it wont run right.
Well, none of your emissions swithcing equiptment will work so off with the tab/tad and run the smog hose from the pump to the crossover behind the heads then cap the air tube in the cat pipe. The head setup should be identical if you use a carbed 302 intake.
TrickFlow
340
Bossier City, La
Jun 13, 2005
  • Jun 13, 2005
Heya, i have ben lookin in the summit mag for that cable ever since you told me about that, and i cant find the part # anywhere... you know it off hand?
You have a PM by the way
P
Paulywalnuts446
84
  • Jun 13, 2005
what size cable? 24'' or 36?
MrKwik
1,008
Kansas City, Kansas
Jun 13, 2005
  • Jun 13, 2005
You can use a factory cable off any carburated fox body car with a 302. Any mustang 85 or older, t-bird, granada etc. Grab the cable bracket that bolts to the intake behind the carb also.
The only holes you need to plug are if you removed the smog pump. and the pipe that rund from the back of one head to the other.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
