Carb Swap and Stock Fuel Lines
well, you don't use the stock fuel rails, but oyu can use the stock lines, adapt them to a Barry Grant (or equivalent) return style regulator (pn 171021), and then to the carb.... easy.
tube nut, tube sleeve, flare the stock line...screw onto a #4 (return) and # 6feed) AN adapter, then buy some line to go to the regulator....
you could just use rubber line, but anything over 12" is not track legal.
