Carb swap, help
SMOKEDYA
Jul 13, 2003
3,637
Tucson AZ
I'm going to switch over to a carb set up from my current fuel injection. Anyone done so can you please let me in on the list it took to do so? What do you think it will set me back buying everything mostly new or used from ebay. I mean from start to turning the key and starting the engine! I know i want the polished edelbrock air gap intake and the K&N full breathing air filter and a barry grant carb, if this helps on the priceing? peace
john:p
you will need...the carb, intake, inline electric fuel pump, fuel line and regulator to start......You will need to wire in a relay for the fuel pump also....do a search on this swap and it should pull up a fletcher site that will entail everything you need to know
