Carb swap Q.
  • Thread starter Thread starter SPEED FREAK
  • Start date Start date Apr 24, 2004
SPEED FREAK
1,448
Regina, SK.
Apr 24, 2004
  • Apr 24, 2004
I am making the swap so I have a quick question. I have never had a carburated vehicle before so I need to know if: a. I can keep my 255 lph fuel pump and regulate it down to 8 PSI (or whatever I need). B. fuel return. Does it work off of the regulator.
Thanks.
85stangt
74
byron, il
Apr 24, 2004
  • Apr 24, 2004
as long as you are using a fuel return off your fuel regulator its fine, you probably already know, but you just set your fuel pressure where you want it and the 8 psi or whatever goes to your carb and the excess goes right back to your tank. good luck with it
SPEED FREAK
1,448
Regina, SK.
Apr 24, 2004
  • Apr 24, 2004
Thats what I was thinking. Thank you very much.
5.0 HOtrain
2,247
New Hampshire
Apr 24, 2004
  • Apr 24, 2004
Not %100 neccesary but carb set ups require more volume than pressure, stock tiny lines dont deliver that. "Just" a good idea to upgrade line size, not must do though, just a thought.
mike.
Iowa91LX
2,616
Grundy Center, Iowa
Apr 24, 2004
  • Apr 24, 2004
You probably wont even need 8psi. I am running 7psi with my setup and have thought about turning it down. With my fuel lines I could probably get by with 4psi.
In a carbed car all you have to do is run enough fuel pressure to keep the fuel bowls full.
I would not recommend running your EFI pump. If you have a 255 sell it on ebay and make some money towards a low pressure fuel pump.
dastang2
2,020
tx
Apr 24, 2004
  • Apr 24, 2004
you would be cutting the fuel pressure over half over the efi pump which will ruin the pump even with a return line regulator most likely. my carb calls for an adjustable fuel regulator set at 5.5. it blows black smoke because i have no regulator
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Fuel Anyone know a part number for a 3/8" inlet/outlet efi quick connect fuel filter that would fit the stock foxbody location?
  • rednotch
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 8, 2025
rednotch
  • dan50
  • Jul 18, 2026
dan50
