Engine Carb'd 88 GT, need centrifugal advance, will an '85 Distributor Work?
pindude80
200
67
38
Cincinnati, OH
I recently bought an '88 GT and put a new engine in it. A previous owner converted it to carb and left the factory EFI distributor in it. We have the timing locked out at 35 degrees. I would like to install a distributor that will have mechanical advance. I think I read somewhere that I can use an '85 Mustang 5.0 HO distributor. I have a MSD 6AL box I will be wiring up as well because I need a rev limiter.
Is that correct that I can use an '85 distributor and have mechanical advance? This is the distributor I was looking at: https://www.rockauto.com/en/moreinf...saLF0BeVToYFnu04v0/tWMIc8rWhYp/LhEwLXaXkgZpsr
Can I run that distributor on my setup and get mechanical timing advance? Also, am I able to run the larger style cap? I think there is an "adapter" on my EFI dizzy that comes off, screws onto this distributor, and that will let me run the larger cap. Is that correct?
What are you going to do with the car??
Billet cams require a steel gear, stock cams use an iron gear... Distributor gear....
for a street car I would recommend a vacuum advance distributor .....
Reactions: General karthief
Mainly street, maybe some drag strip here and there. Do you know if the distributor I linked will work?
I did remember from back in the day that the roller cam had a different cam gear. I did some research and saw that a steel gear is what is needed.
Yes you can. Here is how to wire it:
The ‘85 distributor does mechanically advance and this is a good thread on that:
Reactions: pindude80
Another very useful, post from you, Aeronose, thanks! I will read through the thread you provided the link for this evening after work. I looked up the MSD wiring harness adapter that is in the diagram. I will probably just cut and splice the wires off the distributor since the harness is $30.
Thanks again.
Did you change the valve springs?
Yes, I purchased the Trick Flow 2500100 spring kit. We also had to get custom 6.350" pushrods. I got those from Comp because we ordered Trick Flow pushrods. When we got them the Trick Flow pushrods the box and pushrods were both marked 6.350 but they measured 6.370. I'm glad my friend caught that or it could have cost me my freshly assembled engine; we were already tight on clearance and the extra .020 could have been catastrophic.
Reactions: limp
That would of showed up when you torqued down the lifters if you are doing it correctly.....
