Carb'ed ignition
  • Thread starter Thread starter jete
  • Start date Start date Aug 3, 2006
J
jete
57
Lexington Kentucky
Aug 3, 2006
  • Aug 3, 2006
The tfi ignition on 87-93 mustangs runs with the eec right? If not is it possible to put it on a older carbuerated mustang? 79-86?
D
DouglasOhio
116
Canton Ohio
Aug 3, 2006
  • Aug 3, 2006
i just run a dist. from an older 302 one with a magnetic pickup, and run it to an MSD 6al box then to an msd blaster II coil. You have to figure out the way the wires go into the MSD from the dizzy but its a 50/50 shot. It works great for me.
J
jete
57
Lexington Kentucky
Aug 3, 2006
  • Aug 3, 2006
So I can just take the gear off the tfi distributor and put it on an older one?
bill302
2,131
alabama,gadsden
Aug 3, 2006
  • Aug 3, 2006
click on links below the 79-95 ignition modules are identical...
http://www.partsamerica.com/Product...13F&searchfor=Ignition+Modules+-+O.E.+Upgrade
J
jete
57
Lexington Kentucky
Aug 3, 2006
  • Aug 3, 2006
so your saying I can use the modul with the duraspark?
dastang2
2,020
tx
Aug 4, 2006
  • Aug 4, 2006
you can't use tfi ignition on a carbed engine. rangers did it but they had an electronic carb that won't run without the tfi and vise versa
billison
I like tinted tail
2,607
1,094
184
stl
Aug 4, 2006
  • Aug 4, 2006
http://www.jason.fletcher.net/tech/duraspark/duraspark.htm
http://www.carbdford.com/tech/HEI/hei.htm
J
jete
57
Lexington Kentucky
Aug 4, 2006
  • Aug 4, 2006
Billison
Appriciate it, you said the least and gave the most.
billison
I like tinted tail
2,607
1,094
184
stl
Aug 5, 2006
  • Aug 5, 2006
what i'm doing on my car is, i got a one wire hei setup off ebay, sooo lazy 50,000 volts hard to pass up
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 5, 2006
#10
  • Aug 5, 2006
  • #10
use billison's second link with one of these and you're all set
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
