Carbon Canister cracked
stielow775
Will a cracked carbon canister create a pretty big vacumn leak? Its with a 91 mustang it looks like it has a check valve that comes off the manifold going to a check valve and then to the carbon canister which has a huge chunk missing out of it.
Probably causing my rough idle?
Thanks
Matt
A cracked CC can cause a leak while the purge solenoid is open, and is a fire hazard otherwise (venting gas fumes near a pilot light isn't great).
