Also I forgot to add that the 2.3L is a non-interference engine, thus the pistons won't bang the valves if the timing belt breaks or if a valve is hung open too long. Sounds like the $25 regulator is your problem. While you are there make sure your fuel injectors aren't leaking, they are prone to catch fire if the o-rings detriorate with age and start to leak...
