do-it New Member Nov 23, 2005 54 0 0 Jersey May 15, 2006 #1 May 15, 2006 #1 Anybody install a carbon hood? Just wondering how fit and finish, etc. I dont have a manual, wondering if sirius satalite can be hardwired into it? If not any recomendations for aftermarket...any downsides?
iskwezm 10 Year Member May 24, 2005 4,159 20 79 Rowland Heights,California May 16, 2006 #2 May 16, 2006 #2 use a fm modulator to add sat. radio
S Spdfreak New Member Feb 21, 2006 276 1 0 May 16, 2006 #3 May 16, 2006 #3 Yes, I got the Starmate receiver and it's hooked up through an FM modulator. You can't directly hardwire Sirius. I know, it sucks.
9 99svtlightning New Member Jul 27, 2005 50 1 0 May 16, 2006 #4 May 16, 2006 #4 I have an APC Carbon Fiber Hood. Fit and Finish is perfect and the hood looks exceptional. I'm selling it to purchase a cowl hood.
0 05PhillyStang Member Oct 28, 2004 120 0 16 May 16, 2006 #5 May 16, 2006 #5 Spdfreak said: Yes, I got the Starmate receiver and it's hooked up through an FM modulator. You can't directly hardwire Sirius. I know, it sucks. Click to expand... I heard that you can. But you have to an adapter. It's called a P.I.E. adapter. It allows you to use the AUX button on the stock radio. Also, you say it's hooked up with an FM Modulator. Did you use an actual wire or did you use the stock modulator that uses a clear radio frequency?
do-it New Member Nov 23, 2005 54 0 0 Jersey May 17, 2006 #6 May 17, 2006 #6 fm modulator? how does the fm mosulator work. currently i have the sirius unit sending a signal to pre set station 89.9 but because my commute is long i tend to get interference form stations on said station (& others too) as their signal gets stronger, etc.
bigcat start with the upper hole, and if more traction is May 1, 2005 3,015 1 79 7200 feet May 17, 2006 #7 May 17, 2006 #7 that is an FM modulator. you should be able to switch the channel that it goes to so you can minimize interference.
