  • 1994 - 1995 Specific Tech
cars jumpy
  • Thread starter Thread starter 95blackgt
  • Start date Start date Aug 4, 2004
9
95blackgt
  • Aug 4, 2004
my 95 GT has recently gotten very jumpy when driving....its almost like its running out of gas and jumping forward and then losing its power but its constant....what could this be?
Mrgreen94gt
SIMMA DA NA!!!
448
West TN
Aug 4, 2004
  • Aug 4, 2004
Sounds like a vacuum leak. Look for anything obvious in the engine bay, if that doesn't work, spray some carb cleaner or something around.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Aug 4, 2004
  • Aug 4, 2004
my car does that when the timing is advanced to far. It'll accelerate fine but at a low rpm cruise it'll jump
9
95blackgt
  • Aug 4, 2004
idk what it is, it comes and goes at time but when its there its constant, at almost all RPM's....nething else it could b...like a fuel filter clog or nething?
J
JDaus77
Mount Vernon, IN
Aug 5, 2004
  • Aug 5, 2004
Mine does the same thing when I try to bump the timing up any at all. If I keep it at 8 deg. or less or run without the spout at 20 deg. it does fine. I know I'm leaving a lot of power on the table by running it this way, but I can't find the problem.
9
95blackgt
  • Aug 5, 2004
i havent changed my timing at all....it was fine one day and the next it was shuddery and jumpy ESPECIALLY in higher gears but sometimes in lower also
JJ95GTID
1,141
Phoenix, AZ
Aug 5, 2004
  • Aug 5, 2004
Mine acted that way once. I ended up replacing the TPS. Found a dead spot in the original TPS using a Digi Volt Meter.
D
DRFT_STNG
66
  • Aug 5, 2004
mine does that but only when trying to pull up hill at low RPMs .. and i cant figure out what it is
9
95blackgt
  • Aug 7, 2004
could it be the fuel filter needing to b replaced?
94TURBO5 O
2,509
VA
Aug 7, 2004
#10
  • Aug 7, 2004
  • #10
Check your plug wires and make sure they are not melted anywhere and arcing off some metal.
9
95blackgt
#11
  • Aug 7, 2004
  • #11
no wires r melted and theres no metal touching...but its gotten worse....its like ur running out of gas, cars got NO pickup, NO ecceleration and its shuddering so bad it feels like the cars gonna fall apart at times...
94TURBO5 O
2,509
VA
Aug 7, 2004
#12
  • Aug 7, 2004
  • #12
Gotta be something with your fuel then, maybe. Your fuel filter is prob clogged. Have you ever changed it before and how many miles do you have?
9
95blackgt
#13
  • Aug 7, 2004
  • #13
i bought the car a couple months ago, it has 140,000 miles on it but ive put a few thou on myself and havent changed it yet
94TURBO5 O
2,509
VA
Aug 7, 2004
#14
  • Aug 7, 2004
  • #14
You should try and change it ASAP Cost a couple bucks.
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
