EXTRPR50 Founding Member Oct 7, 1998 370 1 19 Dec 21, 2007 #1 Dec 21, 2007 #1 When I put on 17" or 18" wheels on my 93 notch, are the plates mandatory? If so, what else is needed? Thanx.
hemi_fan Active Member Apr 8, 2004 279 3 28 Ontario, Canada Dec 21, 2007 #2 Dec 21, 2007 #2 wheel size shouldnt require you to put on caster/camber plates... unless they're waaayyy taller than stock or something. You need the plates to correct the camber after you lower the car cuz the stock adjustment will only go so far.
