casting numbers
  • Thread starter Thread starter corey796
  • Start date Start date Jan 31, 2009
C
corey796
85
  • Jan 31, 2009
i have a 2barrel holley on a intake i was told it came from a 197? couger 351.
im hoping to rebuild the carb and try at a later date putting that on my 86f150 for bettter miles i dont to with it so it just make trips to the hard were story if i can get my mile up very good i will park my 06mustang gt what im needing is to look up the casting numbers any 1 have any site's with for casting number info
thanks for any help
ps i came to the classic forums because the intake and tuck are older also i did not want to go hunt up another website for one a none mustang question
N
Nosboss
115
  • Jan 31, 2009
I read that several times and I am still not sure what your talking about...
woodsnake
1,352
15
69
Hicksville, NY
Jan 31, 2009
  • Jan 31, 2009
Are you trying to identify the Holley carb? Look on the "front" of the air horn, and there should be a number there. Post that info, and we can help you out.
If you are just trying to get better performance out of your truck, we will need a lot more info to help with that.
Keep in mind, that it probably just needs a good "tune up", and all that that implies, including a NEW TIMING GEAR SET.
C
corey796
85
  • Jan 31, 2009
sorry there are casting numbers on the ford cast iron intake im trying find out if it is a 351 intake or other also trying to find info on the carb
woodsnake
1,352
15
69
Hicksville, NY
Feb 1, 2009
  • Feb 1, 2009
Dude, I'm trying to work with you.
What engine/parts do you want to identify?
What engine do you want to build?
A "small block" Ford can be either a 289/302, or a 351W. They are not the same.
If you tell us what you have, and what you want to upgrade, we can and will help you out....
D
D.Hearne
11,730
south louisiana
Feb 1, 2009
  • Feb 1, 2009
A 77 Cougar could have had either a 351M or a 351W. If it was an "M" intake, there will be no coolant passages in the intake. If it's a Windsor intake it will. You don't need the casting numbers to tell you this. Your 86 motor could have either a 2 bbl or 4 bbl intake from the factory. If it's got a 4 bbl intake and you want to bolt on a 2 bbl carb, all you need is a Trans-Dapt 2 to 4 bbl adapter to accomplish this. Or simply disconect the secondaries on the 4 bbl carb.
C
corey796
85
  • Feb 1, 2009
thanks man i will check into the adapter plate
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
