  • SN95 4.6L Mustang Tech
Cat-Back or Prochamber First??
  • Thread starter Thread starter mcmmotorsports
  • Start date Start date Jul 19, 2004
mcmmotorsports
689
Danbury, CT
Jul 19, 2004
  • Jul 19, 2004
I have decided on the Mac Flowpath Cat-Back and Mac Prochamber.
Now, I don't know which one to do first since I don't have $500 laying around.
Should I just wait and do both at the same time?
Anyone know how long PartShopper will have that awesome price listed?
kboy262
437
Atlanta-Kennesaw
Jul 19, 2004
  • Jul 19, 2004
You can wait and do both or I would get the prochamber first then the catback. You will get more sound from prochamber than doing the catback. Alot of exhaust sound is rubbed from your stock midpipe. The catback also only gives you very minimal performance gain. The midpipe will help alot in this issue.
9
98SteedaStang
382
Chicago Suburbs
Jul 19, 2004
  • Jul 19, 2004
I would do the prochamber first too.
9COBRA7
116
Just outside Detroit MI
Jul 19, 2004
  • Jul 19, 2004
What kinda sound does the prochamber give out, One like an H-pipe, or X-pipe, or a sound of its own?
propellerhead
1,541
"but what's with the but shots?"
Jul 19, 2004
  • Jul 19, 2004
I did the catback first. I'm thinking I should have gone with the Prochamber first. Either way, I'm getting the Prochamber soon. I believe in this case, 5 + 5 = 15. You should see more benefit from having both, than just one or the other.
Scootr68
102
Tallmadge,OH
Jul 19, 2004
  • Jul 19, 2004
I have the same dilemma...cat back or prochamber first? Only problem here is that we have E-Check and I'm afraid it wouldn't pass seeing as there's no cat's. Would a catted H pipe really have any gains
9
98SteedaStang
382
Chicago Suburbs
Jul 19, 2004
  • Jul 19, 2004
I went with a catted x-pipe because of the E-check. So after about a year the damn check engine light comes on and I have to get MILS to shut it off. Now when emission time comes I have to swap the old stock h-pipe back in the car. This sucks balls! If I would have known this I would have gone off road in the first place.
road rage
433
R.I.
Jul 19, 2004
  • Jul 19, 2004
I went with the mac cat back first and then I got a mid pipe (upr x pipe).
dmarco_4u
194
  • Jul 19, 2004
Its great!! its idle and kinda quite at idle but when you step on it, sounds like the devil is screaming!! with some 40s flows ofcourse
LI98GTStang
1,715
L.I., NY
Jul 19, 2004
#10
  • Jul 19, 2004
  • #10
My vote is also mid pipe first. In my case, I was quite happy with the sound and perf. boost for quite a while with just the mid pipe replaced with the stock catback. I have the older version of the Bassani catted X and never had a problem with the CE light, but have seen some of the later ones have this problem. Never seen any posts from the Magnaflow catted X's having this problem though and would recommend you looking into this type if you need cats for your emissions testing.
twogts4us
4,188
12
79
Dunedin, FL
Jul 19, 2004
#11
  • Jul 19, 2004
  • #11
Definately cat back first...Work the exhaust from back to front. Why would you want to open up the middle without opening up the back? JMO...
kboy262
437
Atlanta-Kennesaw
Jul 19, 2004
#12
  • Jul 19, 2004
  • #12
The biggest restriction is in the middle. Why open up the mufflers when the midpipe only allows so much exhaust to past through to begin with.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 19, 2004
#13
  • Jul 19, 2004
  • #13
I've done the O/R H and the Prochamber...kboy262 knows this personally...
The sound from the O/R H with the stock catback sounds good. The Prochamber is a little quieter but still has a good deep rumble although the pitch is just slightly higher than the H. Oh...and I would go with the mid-pipe first. You will still get a better sound and free up some HP at the same time.
propellerhead
1,541
Jul 22, 2004
#14
  • Jul 22, 2004
  • #14
You can't pass the emissions check with a catted X?
decoy562
1,526
Acworth, GA
Jul 22, 2004
#15
  • Jul 22, 2004
  • #15
Midpipe with the 10% off at partshopper
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
