I have not personally removed them from a stock h so I can't say but as far as the engine light there are 2 ways ,first being to buy the mil eliminators for 50 bucks. or the way I did it cost me 11.88$ and works like a charm, using two sparkplug non foulers on each rear 02 sensor
Cons - Louder, not going to pass an emissions sniffer test (if applicable), smell of unburnt hydrocarbons at stoplights, etc.
If this is for the '03 GT in your sig, yes, you will need to address the two rear O2 sensors - either via a tuner (which can "turn off" the rear O2 sensor monitoring) or with some form of MIL eliminators. Otherwise your check engine light will stay on for the rear O2 sensors not being able to read within the allowable "spec" for voltage/signal.
Are you planning on gutting or cutting out the factory cats and straight piping those sections? Might be better off finding a used X or H pipe for sale locally...
+1, sounds like more trouble than what it's worth. Just find a used midpipe designed for that task and sell your stock one. Or keep it, if you intend to swap it back out for an emissions test.
