  • 1994 - 1995 Specific Tech
Catback removal
  • Thread starter Thread starter 94-302-vert
  • Start date Start date May 3, 2007
94-302-vert
1,947
NE CT
May 3, 2007
  • May 3, 2007
Is it possibel to remove the flow tubes, mufflers, and tailpipes as one piece without doing too much disassembly? Maybe even jsut lettign the rear end hang down to make more clearance?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 3, 2007
  • May 3, 2007
I have heard its possible, but a REAL PITA.
trav_19
810
Jackson, MI
May 3, 2007
  • May 3, 2007
i just cut my tails where they started to bend up over the axel...total piece of cake after that ...are you planning on putting what you currently have back on?? or something?
94-302-vert
1,947
NE CT
May 3, 2007
  • May 3, 2007
I am looking at a pair of muffs with dumps to run in the summer (top down) then I can put the full length back on for inspections and winters...
gcomfx.com
3,690
Republic, MO
May 3, 2007
  • May 3, 2007
You could try warlocks.... then you can go back and forth without much work at all. That's what I plan to do. Although that bypasses the muffler as well.
The Green GT
1,269
Louisiana
May 3, 2007
  • May 3, 2007
If I were you I would get a shop to weld some flanges between the tails and the mufflers. That way you wouldnt have to fight it.
trav_19
810
Jackson, MI
May 3, 2007
  • May 3, 2007
pm drakesdad he has a set of flowmasters with dumps he took off his car
The Green GT
1,269
Louisiana
May 3, 2007
  • May 3, 2007
So you cant pass emissions unless you have tailpipes?
mustang6tee8
375
College Station, TX
May 4, 2007
  • May 4, 2007
Try... puting the rear of the car on jackstands, then use a floor jack under the pumpkin so you can raise or lower it. Then take off the springs, shocks, quads and use the floor jack to lower the rear end down slowly, and see if that gives you enough space to get the catback out.
94-302-vert
1,947
NE CT
May 4, 2007
#10
  • May 4, 2007
  • #10
I am working with Drakesdad for his muffs/turndowns...
BUT since it is a vert I need tailpipes... Also with my son in the car (2.5 years old) I can't have a lot of resonance so I need tailpipes when winter comes and the top is up most of the time...
So is it possible to remove the pipes without disassembling everything around the rear end? (shocks, quads, springs)?
1TallMF
955
Montreal
May 4, 2007
#11
  • May 4, 2007
  • #11
Probably not unless your tailpipes have a flange just behind the rear axle where it starts to straighten-out. My Mac system has them, but they're not that common. If the tails are 1-piece up to the muffler, you'll probaby have to lower the axle or cut the tails somewhere.
trav_19
810
Jackson, MI
May 4, 2007
#12
  • May 4, 2007
  • #12
....where your tails connect to your mufflers theres not a clamp there? if so you can undo it and probley twist them out ..you will need to get the rear of the car high though or you will smash and rub your tips...when i put my new cat back on i started at the rear and twisted them all around and got them into place doing it...so i would imagaine you could work them out just the same.....first thing i would do is undo the flanges up where they connect to the h pipe then undo the rear clamp behind the muffler take the mufflers out then start pulling and twisting the tails out
94-302-vert
1,947
NE CT
May 4, 2007
#13
  • May 4, 2007
  • #13
Nope.. Muffs were welded in place...
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • brandyn200
  • Jun 20, 2026
AeroCoupe
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
