SWEEEEEEEET! I assume you are staying na? I would check around, there are some pretty good aftermarket NA cames for the 4v and you can make some series power I would thinK!![]()
That's the plan, I mean I know it's expensive but since the motor is coming out now would be the time to do it to help cut on install costs. Believe me I've been researching cams to death
Comp has some nice grinds and then there is the FR500 kit which a lot of 4v guys are happy with. If I have the heads PnP along with my supporting mods (LTs) and then maybe later on have the intake worked on some (possibly by Nazman) I could see some pretty good NA numbers. On the highend people have made 400 rwhp NA, but I'm thinking I could be in the 340-360 range I believe depending on how radical I'd want to go. I'd more then likely keep it in the stage I or II range just so I can keep it as a DD without all the headaches of overly aggressive cams. That being said I think it'd be cool to have almost 400 flywheel hp on a NA 4.6. Not to mention a 30-40 rwhp should be nice kick in the pants esp if I add steeper gears later on. Oh yea that kick ass chug-a-lug will top it all off.
