How do you tell if the cats are clogged?
I have been working on a problem for awhile now for a code 94. The code is for the passenger side smog system, this I know. I have tested all the smog valves, vacum selinoids and computer grounds, all are ok. I did find problems with the smog hoses two were cracked and have since replaced them temporary until I can find the pre-formed hoses. Anybody know where to find new hoses? Ford discontinued them, I currently used a straight peice and bent it, but it is to close to the headers.
I don't know how to check the "check valves" that go to the exhaust, chilton say to just visually inspect them, well they look fine. But I am still getting the code 94 and it still makes a rapping noise (like backpressure). When you take off the hose that attaches to the check valve for the cats there is some backpressure that comes out back from the cats. Is it supposed to do that? Or is the check valve bad or the cats clogged or both?
