Catted H pipe question
  • Thread starter Thread starter DMAN302
  • Start date Start date Oct 28, 2006
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Oct 28, 2006
  • Oct 28, 2006
Also posted in talk due to lack of attention...sorry, anyways...
Ok looking at making the car a little more enviormentally freindly...(AKA local ministry has created a crew of 'smog cops', a mobile unit that likes to take a look see for emissions violations. Anyhow, I found the MAC catted H pipe to fit my MAC long tubes..however the piece has the air line to the smog pump. Now since my heads do not have the emissions port to run the line from the heads to the smog pump line, I can't really run a line from the smog pump to the cats from what I can tell. Now if I don't run the air line from the smog pump to the cats, will the cats be damaged as a result of not running the above mentioned line? Can I crimp off the line at the H like my present pipe has? Or will the lack of a line pumping air to the cats damage them?
95GTV8
386
Washington State
Oct 28, 2006
  • Oct 28, 2006
make friends with the cops? If you don't have the smog-pump pumping fresh air into the cats they will sour much faster.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Oct 28, 2006
  • Oct 28, 2006
Could I run the line directly from the smog pump to the cats and leave the smog air intake open to the atmosphere?
Dean85GT
502
Thorold, Ontario, Canada
Oct 28, 2006
  • Oct 28, 2006
I have a questions. You said you still have your smog pump right? Well what is it doing? lol Is it just pumping air under the hood and where is it getting the air from?
D
Deleted member 87397
Oct 28, 2006
  • Oct 28, 2006
DMAN I answered you in talk, but I will also say here that if you have your smog pump still, run a line straight fom it to the h-pipe if you're worried about it.
HISSIN50
34
129
Oct 28, 2006
  • Oct 28, 2006
For aftermarket cats, some can be run without air injection. But as suggested, I'd just run a line from the AIR pump to a check valve (protects the pump if you have an afterfire. That's why we have it in OEM form) and then to the cats. On a stock AIR system, air is diverted to the cats 98% of the time anyhow.
Some aftermarket cats dont require extra air (it seems to me that they free up O2 in the reduction stage). So what cats come with the H-pipe and the cat manufacturer's recommendations will kinda decide that. I'd run the line if you have your AIR pump installed anyhow.
Good luck Derek.
Tonys96Cobra
professional deer "mounter"
Oct 28, 2005
29
Syracuse
Oct 28, 2006
  • Oct 28, 2006
Did you bypass the smog pump with a short belt to save power? If so, hook it back up, you will never feel the difference, the smog pump takes about 0 hp to run. And that will help your cats lifespan.
Resolved Three way cat converters..?
  • PonyGTrider
  • Nov 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
PonyGTrider
L
Exhaust 95 gt pypes catted x pipe
  • Lx5.0fiend
  • Aug 22, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 18, 2025
revhead347
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
