CC Plates
dcurtis
688
I am going to order some new wheels, tires and a sportline kit soon, is it best to just go ahead and order some caster camber plates with wheels, tires and springs? Read too many posts with people ruining tires due to lowering without cc plates. Is there anyting else I will need to keep my front end from eating tires, so far I am going to get new wheels, tires, sportline kit, new front struts and rear shocks, and CC plates? What are some good cc plate brands to look for?
Anytime you change the geometry of the suspension it is a good idea to get caster/camber plates. This will make it much easier to get the alignment correct. I've got the Maximum Motorsports C/C Plates and haven't had any issues with them. I would either get the Maximum Motorsports or the Steeda's since they are designed year specific. Some other brands just make them generic to cover all years. Also, I prefer the steel C/C plates rather than aluminum.
I like your list. If you need end links or sway bushings, that'll be as good a time as any since the bar will be loose from the FLCA's. New isolators?
If you have the cash and dont want to be back in there for a bit, some fresh FLCA's might be nice. At least take a look at your FLCA bushings before you start - if they're toast you might want to renew those after the springs come out.
Good luck.
When i bought my 93 it had been riding on lower springs and chewed through tires. Ford motorsport steel cc plates i purchased. Installed no problem, aligned awesome. I put a set of steeda i think... In a friends car. Aluminum which i didnt like. Aluminum doesnt slide as nice as steel while making adjustments. I had to pry on the friends car and the aluminum was easily damaged of course. Ford motorsports are a decent price too. Oh also, once the alignment is right you'll just feel better about the whole upgrade.
Well I have about 3000 to spend but I only want to spend about 2000, thats with wheels, tires, struts, shocks, cc plates and sub frames(full length) so far. And hopefully have enough for lcs's and uca's.
