CEL: P1443 EvaporativeEmissionControlSystem-Vacuum System-Purge Control Sol...
ocelot
96
Ok so I got a CEL and went to autozone to get the code pulled, and heres what I came up with:
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault.
The light goes on and off, but when its on its usually on for about a day or something. The car seems to be running fine when the light is on or off, but I want to get it fixed. What exactly could the problem be, and how will it effect the car?
what year car/truck?
Just change it out, part cost like $25 bucks.
Car will run like azz if you let it go.
I have to change mine in my 97 GT.
Do a google search and you can learn all about this part
Part# E6ZZ-9C915-A :It's the small plastic valve on a vacuum hose directly behind the TB against the firewall
This fixed my code and it's been almost a year and no more 1443 code. Before you replace anything else, try that part first.
false info, this has nothing to do with drivability. the purge solenoid will have a color coated hose orange or green. just be sure to make sure to change with the correct part. It's only $40 bucks or so with tubing all it will do if you don't change it is throw a check engine light.
:stupid:
I had that code for like 2 years, car ran fine, but had to get it fixed for smog testing.
green_fow_six said:
:stupid:
i have had the code for about 2 years now and last time i got it smoged it stayed off for the whole test i passed with flying colors and on the way back it lit up for the same code :rlaugh:
No its not false info, my 97 ran like crap with it bad. (as designed)
Your statement make no logical sense, if it was just a light only. No cars would have working emissions systems.........
I changed mine when I got back from the field, car runs great.................
Get your facts straight before you slam a Mechanic....................
:lol: :rlaugh:
u tell 'em. :nice:
