crazypete said:
As long as the thread is resurrected.....
and mostly on topic...
What about lexan/ non-glass rear windows? Are these any good in a regular service street car.
After removing the hatch a few times before, I'd be glad to be rid of that horrible mass of weight. I need an assistant when mounting that thing or I get gilloutined.
In my state, they are illegal in a regular service street car.
The argument for removing weight is a good one, however- it doesn't do any good unless it's removed from the right places. The rear of the car isn't where Mustangs need to go on an diet, they are seriously off balance and nose heavy. If anything, they are too light in the rear as it is. Anyone who knows how to set up a racecar takes everything that they
need in the front which is relocatable and moves it to the back. This still won't fix the problem, so more weight needs to be shaved from the front. This is true wether you want to carve corners or just go strait. In AutoX you want it 50/50 front to rear. Removing weight from the rear would be disasterous as they are front heavy anyway, unless so much has been shaved off the front that trimming the rear can be afforded. Building the perfect corner carver involves completely gutting it of anything not essencial to racing to get it as light as possible- then they add weights back to the corners as needed to balance 50/50. Guess which corners get the most added? Even in drag racing, everything from the spring rates to the shock valving is designed to transfer what weight there is to the rear on the launch, because that's where you want it in order to hook hard. Just because it was a perfect opportunity for experimenting, before I installed my stereo I made several runs with my empty trunk. Then I installed well over 200lbs of stereo equipment into the hatch, and ran them again. General rule of thumb is that every 100lbs of weight you shave off the car should net you one tenth of a second in the quarter. So, I could logically expect to run at least two tenths slower with the extra 200+ in the trunk. It didn't affect my average even one tenth, not one run was slower, and a few of them were a tenth faster than any previous runs- same day, same weather, same place, much heavier.
As for the structural integrity of the hatchless car- done that too. Not without a windshield mind you, and I believe that's where most of the difference was made. When I was getting it painted I had the opportunity to run up the road for gas, and aside from a little extra wind, it felt the same in curves and launches, no extra creaks or noticable twisting, handled fine right up into 4th gear. Didn't launch as well, which is no surprise- there wasn't any weight over the rear tires. With a built rear suspension there wasn't any wheelhop, just didn't want to stick. Refer back to the weight placement issue, this makes perfect sense. Now, take off the hatch
and the windshield, and you create a regular windtunnel. It's going to try to take off like an airplane- it'll be all over the place. Of course it'll ride like crap, nevermind that the windshield is far more rigid than the two spindly A pillars. The fact that the hatch has a weatherstip around it means nothing in terms of rigidity, that would only make a difference if the seal were a vaccuum, which obviously it isn't or we couldn't breath inside. The three points that are connected don't offer any more torsional support than a heim joint. If they did, nobody would blow a hatch open on a hard launch, which isn't uncommon on the strip- people blow them open all the time. Hell, I've done it on the street and I have full length subs welded in, even with the latch adjusted so tight it's hard to close it. Ford designed it that way as a safety issue- when it's stressed it pops. It is
supposed to. Now, if it were a four point pin on, maybe- but I don't see many streetcars with pin on hatches.
