change the timing?
  • Thread starter Thread starter poohbertino
  • Start date Start date Aug 25, 2005
P
poohbertino
  • Aug 25, 2005
Ford sets the stock timing For a 200 I6 at 6* BTDC. How would I be able to reset it to 10*-12* BTDC. What exactly would I have to do? any suggestions?
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Aug 25, 2005
  • Aug 25, 2005
First you need to hook up a timing light. Then its as simple as temporarily removing the vacuum line that goes to the distributor, loosening the bolt that holds the distributor in place, and turning the distributor until you reach the desired timing. Then tighten the distributor back down and recheck to make sure the settings remain intact.
Reinstall the vacuum line and remove the timing light.
All this will be in vain if you do not have a timing light and know how to use it. I suggest finding a friend who has one and has some basic knowledge.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2026
skidad
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
