  • SN95 4.6L Mustang Tech
Changed Alternator, Now Have Coolant Problem!
  • Thread starter Thread starter chrisconsin
  • Start date Start date Aug 31, 2007
chrisconsin
43
Washington
Aug 31, 2007
  • Aug 31, 2007
Changed my alternator, while doing that I checked and cleaned off some corroded wires and connections, after I put the new alternator on and fired the stang back up. just a few miles later my MIL light comes on, read codes and got one
P0118 - ENGINE COOLANT TEMPERATURE CIRCUIT HIGH INPUT
I also noticed that my factory temp gauge is not working now.
Im only putting out 13.0 volts max at highway speeds due to pully swap, so excessive volts is not causing it.
Would changing out the sensor fix this?
I triple checked everything and it appears nothing is disconnected.
I did a search but couldn't find anything.
THANKS IN ADVANCE
-Chris
2000 GT
Superhereaux
chicks make me feel inadequate
538
South Texas
Aug 31, 2007
  • Aug 31, 2007
the a ECT sensor is awfully close the the alternator, guessing maybe you hit it during the install
chrisconsin
43
Washington
Sep 1, 2007
  • Sep 1, 2007
Ya I must of bumped it, anyway replaced the sensor and good as new so
PROBLEM SOLVED
thanks superhereaux!
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
