changed my mind, i wanna stay with EFI
I recently posted a question asking how to convert my 87 GT to carburation since i am putting a 351 with a carburator on it in this car. Well i changed my mind. Can someone point me in the direction on how to make this 351 EFI???? i know i will need an upper and lower intake...and then what?????? Thanks in advance for any help guys.
P.s. Also how important is getting a proper fly wheel for this 351? I've heard not a big deal, and others say it is???
Derek
Simple method:
You will need an aftermarket MAF designed to use 24 lb injectors and some 24 lb injectors.
Complex method:
Buy a Tweecer or Moats Tuner setup. Once you get it figured out, you can use all kinds of different MAF's and injectors. It may take a while to learn, but if you are good at it, it really does the trick.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
