Changing differential this time
  • Thread starter Thread starter feifong
  • Start date Start date Jan 16, 2006
feifong
319
mesa
Jan 16, 2006
  • Jan 16, 2006
Im gettin my differential switched on my 83 vert found one off a 92 with disc brake conversion at a local boneyard for 250. What do i need to complete this change? It has the calipers rotors on it btw thanks
sunil6784
620
Boston, MA
Jan 16, 2006
  • Jan 16, 2006
Chances are its from a thunder bird. You need a proportioning valve and one other thing, maybe master cylinder i think ? Do a search on it. Jrichker always posts how to complete the swap. He's done it.
sunil6784
620
Boston, MA
Jan 16, 2006
  • Jan 16, 2006
I'm in a good mood...
Here ya go...
http://forums.stangnet.com/showthread.php?t=608143&highlight=rear+disc
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 17, 2006
  • Jan 17, 2006
feifong - are you just changing out the differential or the ENTIRE REAREND HOUSING? The differential is only the 'guts' of the rear end located in the housing -- to change it you have to remove the rear cover, remove the carrier bearing caps and pull it out. You need to measure backlash before you remove it -- because with a different diff, you may need to shim it differently to get the proper spacing so the gear mesh is the same.
If you're replacing the whole housing -- MUCH easier in terms of mechanics. As others have said -- you'll likely need the proper brake line fittings/hoses, and the correct proportioning valve. The last piece is REAL important. If the front to rear balance isn't correct, you can end up with a car that either locks it's rears too soon (a BIG problem) or one that isn't taking any advantage of those new discs you'll have back there.
feifong
319
mesa
Jan 17, 2006
  • Jan 17, 2006
This sounds complicated i will try it. Changing out the whole rearend to 8.8
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Manual disc brakes
  • Butchd88
  • Feb 28, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
