Changing Fuel Filter, no pressure relase on fuel rail
GoldnGT
427
Birmingham, AL
Yeah its my fault. I have a wet kit installed so i can't use the fuel pressure release on the shrader valve... what will be the best way for me to change my filter this afternoon? i can let it sit for a few hours I know, but how do i keep from getting sprayed in the face by all the pressure? Is there a way to relieve the pressure otherwise?
Mike
unplug the harness from the fuel cut-off switch located in front of the drivers side tail light. You pull the trunk liner out some to see it. Once it is unpluged crank the car and let it idle until it dies. take about 10 minutes usually until it runs out of gas.
tjm73 said:
Stock fuel filter by the gas tank? Just unplug it and plug the new one in. You'll loos less than a few onces of fuel. You won't get sprayed in the face.
You WILL get sprayed if you don't release the pressure unless your filter is so dirty you don't have any pressure.
The method I posted above is the method from the manual. It's simply and it works.
