- Aug 30, 2005
- 347
- 0
- 17
Is there a way to change the fuel pressure with a stock regulator? If so what should it be set to ...40psi?
It can screw with the A/F trim. Manifold vac is crudely inversely proportionate to throttle-opening-change per time. The computer knows pressure goes up as you get into the gas and if pressure is indeed not going up, you could run a bit lean until the puter figures things out (if it is able to adapt). Some 94-95 GT owners have tried running with no vac line to the FPR and the results were not good.fastfox86 said:I hooked a gauge to the vacuum line on the FPR on Sat. while I was running some tests on my EGR and it had no vacuum. What could be causing this? What negative effects is it having on my engine if any?
The EVR doesnt have an affect on the FP vacuum line. The EVR controls when vac is applied to the EGR, whereas the FP vac line is attached to manifold vacuum.fastfox86 said:Thanks Hissin. I think i have bad EVR controls, but I don't know if that would have any effect on the FPR vac. or just EGR operation.
You can't pull KOER codes or any codes period?AZNEAL311 said:My car has the T5. I have BBK CAI with RAM air kit. BBK 75mm TB, Edelbrock Performer RPM2 intake with Performer heads. There is a Cam but I am not sure on what kind it is. I have Flowmaster 40 series mufflers but i still have stock exhaust mainfold with cats. Could that cause some of my surging problems. All the air going in but nowhere to exit.And I cant pull codes for one reason or another. It will not enter test mode. Tried several things with no positive result. It is converted to MAF. So i am thinking that is whewre my problem lies.
Here's some info on a no code situation.AZNEAL311 said:No I cant pull any codes at all.
