Changing MAF
  • Thread starter Thread starter ferga
  • Start date Start date Oct 16, 2007
F
ferga
22
  • Oct 16, 2007
Hi
I have a 93 GT, auto, Edelbrock Performer heads, 3.73 gears.
If I change the MAF from the stock size to the 70 mm, calibrated for 19 injectors should I get some improvment, I know that one part by itself doesn't show much but the sum of the parts will.
What do you think?
Thanks
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 16, 2007
  • Oct 16, 2007
Yeah, the factory MAF is quite small and can be a restriction once you make some changes to the engine. I'd say you would see some small gains, maybe not noticeable right now but if you change the cam and intake you'd probably notice more.
ninety15.0
1,336
  • Oct 16, 2007
I think it would be worth it if you have bigger plans for the car down the road. For the time being you would see a much bigger improvement with a shift kit and converter! That would make a night and day difference in your car! Good luck man
HISSIN50
34
129
Oct 16, 2007
  • Oct 16, 2007
See the Sticky for info on retrofitting a 94-95 Mustang MAF to a fox.
Good luck.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
