Changing my oil myself, few quick questions.
Killerrobotjews
62
What oil filter would you suggest?
What Oil would you suggest?
What all will i need to buy to change it myself, if i have nothing at all?
I know i need an oil filter wrench, do i need any gaskets?
thanks!
1. fram or mobil
2. mobil or amsoil
3. catch pan for oil, oil filter wrench
4. no gaskets are needed
suggest: lucas oil treatment with your new oil and a can of restore to put in your gas tank to clean the injectors.
ProCharger GT said:
1. fram or mobil
2. mobil or amsoil
Thank you, What weight oil should i use. What specific oil would you suggest? mobil and amsoil both have a bunch of sub-brand names.
Whats the lucas oil treament, and more info on the restore stuff?
I reccomend 5w30 - I've used both fram and mobil1 oil filters and had no problem.
Lucas oil treatment: http://www.sbmoc.com/TechTips/oil treatment/
http://www.lucasoil.com/products/display_products.sd?iid=25&catid=2&loc=show
Can't find info on restore, so here is some for lucas brand:
http://www.lucasoil.com/products/display_products.sd?iid=26&catid=2&loc=show
people used to say copper autolite 764's (i think that was the number) were good
keep the stock temp range.
i haven't changed my plugs yet so listen to these other guys. i wouldn't know
motorcraft filter (820s) and syn blend 5w20 is what i always use :nice:
