- Aug 7, 2008
- 97
- 0
- 6
Was considering a gear change so was also considering a kit to calibrate the speedo correctly. Problem is, can this gear swap be done with the transmission in the car? Level of difficulty?? Job better left for tranny shop???
83-95 Mustang Speedometer Gear Kit For T5 With 3.73 Rear Gears by Ford at LRS - Same Day Shipping!
When using a speedcal, do you leave the stock driven speedo gear in place? Would I have to remove my current 23 tooth and reinstall the stock 18 (2.73 stock ratio) tooth speedo driven gear and then install the speedcal??
