charge motion control valves
gpp
137
why cant you just take the guts out of the original plates instead of buying new ones.sounds to easy and theres probably a reason why you cant do it.
If I am not mistaken the factory ones are all connected so if you gutted one there would be holes where air could leak from cylinder to cylinder and then the ends would be open also. I would think you could just disconnect the systerm and wire them open to see if it helps.
