So I have some horrible charging issues... actually my car just doesn't charge. During my motor swap 4cyl to 5.0 I went with a 3g upgrade for the electric fan and moved the battery to the trunk. Now after all is said and done it won't charge worth crap. Stock volt gauge(I know they suck) doesn't even go 1 bar above red EVER. If the car runs for more then 30 seconds after charging for like 2 hours via a battery charger it will start to surge and eventually stall out. Also my alternator is brand new rebuilt from pepboys with max output of 143A so I think that can't be it. So here is what I think... but I'm looking for other ideas as to where my problem might be.
1. My optima yellowtop battery is crap. I believe this to be a great possiblity since it won't even have a charge after I charge for hours on the charger.
2. My spicing for the 3G upgrade is bad. I used solder to connect the two wires and then tape the crap out of them... this may be an issue? I don't know any other really clean way to do it.
3. The fuse I used for the 3G upgrade may be not allowing power to go from the alt to the battery?... I really can't see this being the real problem though... but maybe?
4. The wire between the battery and the solanoid is not the right stuff? It's a 4G wire that I bought from partsdirect I believe... I doubt that could be it since I got the link for that part off this site and someone else used it but I've kinda ran out of ideas.
These are my ideas for checking on it tomorrow but I'd like to see what you all think and if I missed anything?
Situation: Car only drove less than 2miles today with about 3/4 at highway speed and the other 1/4 stop sign to stop sign. It stalled when I hit my driveway and rolled in.
I had nothing running either. Only the engine computer stuff, msd 6al, and aftermarket fuel pump. I wouldn't even want to know what would have happened if I had on my wipers, headlights, radio, or even the fan. Car runs great once it gets moving. It has a horrible delay coming off stop signs where it seems that it might stall but catches itself and pulls fine. Car stalled leaving the driveway, after charging for hours, when I turned the wheel and the powersteering pump put strain on the motor. It also barely restarted and it only ran for maybe 20 seconds in the driveway.
If those 4 things check out fine then I'm at a huge loss here :-\ I've been chasing this problem for a few weeks now and it's not looking too good. I need to move next week and drive it 6 1/2 hours... so
Help please.
I had nothing running either. Only the engine computer stuff, msd 6al, and aftermarket fuel pump. I wouldn't even want to know what would have happened if I had on my wipers, headlights, radio, or even the fan. Car runs great once it gets moving. It has a horrible delay coming off stop signs where it seems that it might stall but catches itself and pulls fine. Car stalled leaving the driveway, after charging for hours, when I turned the wheel and the powersteering pump put strain on the motor. It also barely restarted and it only ran for maybe 20 seconds in the driveway.If those 4 things check out fine then I'm at a huge loss here :-\ I've been chasing this problem for a few weeks now and it's not looking too good. I need to move next week and drive it 6 1/2 hours... so
Help please.
