chatter when i am excelerating in first gear
Where's the noise coming from? Inside the car, outside the car, below you, engine compartment, rear end, etc. Need more info. Is it only in first it happens? Does it happen at idle, or when you floor it?
do you have an aftermarket shifter, cause mine makes a chattering noise when excelerating in lower gears. could be that.
now the chattering is worse with the cams. it chatters at idel :doh: at least i hope its just the shifter shaking in the tranny :shrug:
well its definatly comeing from underneath the car, not from the inside. It almost sounds like a metal rattle but i looked under the car and didn't see any loos parts or rub marks :shrug:
