Cheap Power
  • Thread starter Thread starter Santeeford
  • Start date Start date Sep 28, 2007
Santeeford
27
San Diego
Sep 28, 2007
  • Sep 28, 2007
Hey guys. I have a 93 gt. I have about 300 bucks to spend on something. I want more power out of it. I already have underdriver pullys, cold air, headers and catback exhaust. What could i do for 300 or less to make decent power. Or also some basic adjustments to make some better power. I have this guy with a 99 gt conv. talking all kinds of trash saying he can beat me in the quarter mile. I want to shut him up. Thanks
C
cjnecessary
70
richmond,in
Sep 28, 2007
  • Sep 28, 2007
Get a used N2O kit off of ebay. Like this one.
NO active e-bay links
Thanks
Santeeford
27
San Diego
Sep 28, 2007
  • Sep 28, 2007
I was kind of trying to stay away from nos. What do you guys think my chances are against the 99?
squeak93
2,331
408
164
Joplin, Missouri
Sep 28, 2007
  • Sep 28, 2007
300 bucks and more power. Only way to get a noticable difference is with the funny chit.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Sep 28, 2007
  • Sep 28, 2007
Yep spray it.
ninety15.0
1,336
  • Sep 28, 2007
Is your car a 5 speed? Is the 99 a 5 speed? If you are both stick cars then you will loose...no questions. But if you are a stick car and he is an auto...you stand a chance! My buddies automatic 00gt coupe with 4.10s and CAI runs a 14.2 all day.
for 300 bucks you could buy a set a gears ($180) and a tracklock rebuild kit ($50) and install them yourself to pick up at least .25 seconds in the quarter. That should help even the playing surface.
Or you could look into a used or junkyard explorer intake and throttle body combo. This will probably net you 25 hp or so. Maybe worth .1 in the quarter. Not a huge gain but it would help. That could be had for around 300 bucks...and its a simple install.
The spray is always a good option. Theres nothing complicated about a small dry shot. One step colder on the plugs and pull some timing out!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 28, 2007
  • Sep 28, 2007
On a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
Aluminum driveshaft: (courtesy of shawn13) It needs to be from a 92-93-94 Aerostar AWD and you will need the u-joint, part #353 from NAPA. It should bolt right up after the u-joint swap.
*1.) A metal flange adapter is available from: http://www.kustomz.com/cat3.html . Buy the TR70 for $44.95.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
The A2A, AA, AB, etc, on the end of the part number are minor changes that do not affect the calibration.
Flavadave4
1,044
21
49
Utica, NY
Sep 28, 2007
  • Sep 28, 2007
What are you running for a mid pipe, if you have the stock 4 cat one throw it out and get an off road style, or even high flow cats.
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Sep 28, 2007
  • Sep 28, 2007
You can get a decent o/r mid pipe for $300. Then, save and buy some gears.
Just remember, there is always someone out there that will talk chit or be faster than you.
mrmustangman357
763
Sep 28, 2007
#10
  • Sep 28, 2007
  • #10
spray a 100 shot, and put on some 3.73s. You will beat him
FoxRod87
243
Carolina
Sep 28, 2007
#11
  • Sep 28, 2007
  • #11
how about some Nitto drag radials. Then you could get him out of the hole and hope he doesn't catch you. This is if you spin alot. Also they are a good street tire and don't wear out like a BFG or a Mickey T. You can get some for around 300 bucks. Traction is everything at the dragstrip. Or you could just do a dry 75 shot.
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Project Fox Revival (please send help)
  • sleep-e
  • Jan 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
KRUISR
