There is not a thing wrong with the set up you have already been shown infact those are good quality parts at a good price, however you said you wanted all of the "all ford parts" options and there are a few that have been missed. There are setups that uses newer parts for beter performance and less drag. MustangSteve of www.MustangSteve.com sell 13" cobra front disc brake brackets and which utilize the original spindles with the newer parts.
http://www.mustangsteve.com/cobrabrake_left_close.JPG
Ultrastang of www.ultrastang.com sell rear Cobra disc brake brackets as well as SN95 rear GT disc brak brackets that will bolt up to an original 8" or 9" rear end
and I DazeCars of www.dazecars.com sell Ford SN95 dual piston aluminum caliper GT disc brake brackets that use 99-04 calipers and 94-04 11"rotors and your cars original spindle and hub.
can your sn95 brackets be used with the cobra brakes too? it is my understatnding that on 94-04 GT's you can just swap the Cobra brakes on them, so you bracket would theoretically work right?
also, if i buy your brakets and use the GT brakes, i will keep my drums on the rear. I was thinking I could use a MC from a fox body since they were a disc/drum setup. do you know if the MC from the fox will bolt up to my firewall and pedal?
