Cheating Through Emissions!!
5.0stang_gt
62
Is there anyway possible way that I can pass through a moderate level emissions test without cats. If there is what can I do to increase my chances. PS I don't have enough money for a catted x or h pipe. The stupid bastard I bought it from didn't tell me it didn't have cats. Thanks.
So glad there in no emission testing around here, yet. You can do a search on emissions. There are tons and tons of emissions threads. Maybe someone else will have a little more information. Good luck.
Edit: or like he said get into a line where it looks like the person needs some quick $$$$$.
I dont know where u live but in PA if you dont pass they will do up to $150 worth of emission related work to your car (usually exhaust) and if it still doesnt pass then you get a waiver sticker that lets you go for another year. But then you have to have it all done again next year if u drive it more than 5000 miles.
you will fail the visual.
if they usually dont look underneath then dump a bottle of "guarenteed to pass" in it will help, but without cats it's probably still going to fail. drop your fuel pressure and timing.
lowering the fuel pressure wont do anything. the computer controls a/f ratio and emissions at the rpm ranges they test at. the lower you set the timing the cleaner it will run. i know in california the lowest you can run is 8* so thats what i ran on my car. if where you live it doesnt matter, then go lower. i had a friend who worked at ford and when they had to get a car to pass he said they would set the timing to 0*. the car hardly ran but it would pass. clean the fuel injectors. run a 195* stat
New cap, wires and plugs.
Side gap the plugs (important), put 87 in the tank with 6 oz of PURE acetone (reduces surface tension of gas, makes better combustion), set timing to 8 or 9 degrees, disconnect the AIR tube and put a hose on it and dump it to the fender(dump some exhaust), connect the smog pump feed hose to the crossover behind the heads (earliest smog injection possible), Pipe pcv hose into the fender(dumps the waste into the air rather than the tailpipes)
If you're marginal, this will help.
Might be easier to have a lump of cash accidentally fall out of your pocket into the inspector's hands and get it over with without macking your car up
Run a full tank of Textron concentratred fuel injection cleaner. Follow the instructions. Then run car on highway for 1/2 hr very low on gas and 3-4 can of drygas before you visit inspection station.
before the inspection (not at home, at the smog station or around the corner) put a smaller pulley on your smog pump, but dont leave it on there unless u wanna pinch for a new one
