Check Engine Light HELP!!
ironexecutioner
35
I have a 1997 Cobra with Full length LT headers by hooker, I also have the o/r x pipe from hooker as well. I have o2 sims on my rear o2 sensors and my front o2 sensors are just inserted and hooked up. I am throwing a check engine light though... PLEASE HELP i wish to be rid of this! thanks
Yea let us know what the code is.. I had the same problem, and it turned out after some code pulling and some re-checking, that I had a loose wire on the driver side front o2 sensor where I extended it.
Mirrahasmycar said:
recheck the connections on the o2 sensors, if that doesn't fix it, drive to auto zone they will tell you exactly what it is for free
they will tell you exactly what the code is... thats about it.. they are not qualified to diagnose cars...
codes are not even half of the info you need too solve some problems... just get the code from them.. and post here DO NOT BUY ANYTHING UNTILL YOU POST HERE
