  • SN95 4.6L Mustang Tech
check engine light question
  • Thread starter Thread starter Bullitt00606
  • Start date Start date Jan 29, 2006
Bullitt00606
34
  • Jan 29, 2006
i just had my o/r prochamber installed and while doing so, my mech asked if id need MIL elims. I said no as I have a predator and could turn them off so my check engine light doesnt come on.
yet after driving it for several hours, the light hasnt come on. is there some thing wrong?
Kronos
101
the boondocks
Jan 29, 2006
  • Jan 29, 2006
when i put my o/r x pipe on the light didn't come on for a couple of days
i think it might just take the computer a few days to realize something is wrong but don't quote me on that its just a guess. or maybe since you have a predator it doesn't read it the same way.
O
OleYellarGT
64
Charlotte, NC
Jan 30, 2006
  • Jan 30, 2006
First start by using the predator to pull the codes, see if there is another problem such as upstream O2's or possible leak. I too have a predator but still used the mil elim just for this reason, plus when I go for an inspection, pull the o/r tubes out and put the cats in, there is no code thrown....also, if you use a catted H or X pipe that uses only 2 cats you will still need to use mil elim.
propellerhead
1,541
"but what's with the but shots?"
Jan 30, 2006
  • Jan 30, 2006
I ran into the same thing. I installed an off road midpipe and the MIL never came on. Diablosport support confirmed that the rear 02 sensor test was already shut off in my Performance Tune. I guess not all Performance Tunes are like that. I had to tell them which computer code I had before they could confirm if the test was already shut off or not.
LB0193
171
IL
Jan 30, 2006
  • Jan 30, 2006
Why would you still need mil's with a catted H-pipe? Also who makes a H-pipe that is easy to switch cats in and out?
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
