  • SN95 V6 Mustang Tech
Check Engine Light
  • Thread starter Thread starter 97WhiteStang
  • Start date Start date Nov 6, 2004
97WhiteStang
43
Vienna, VA
Nov 6, 2004
  • Nov 6, 2004
Ok so my check engine light came on the other day and i ran the codes and it came up as a bad cam position sensor. Today i get the sensor put it in, the old one was obviosly broken, start up my car and the damn light is still on. I drove around the block a couple times hoping it would go off but its not. so my question is do i need to erase the codes or should the light go off by itself?
Thanks for your time,
Jake
84convertablegt
589
Columbus, OH
Nov 6, 2004
  • Nov 6, 2004
did u remember to unplug your battery while you were installing the new sensor, if you didnt your computer will still have the code stored and the light will still be on. just unplug your battery for about half an hour and that should do it. If not, the problem still exists. anytime u do anything to the car, disconnect the battery and let the computer learn everything again.
T
Tru_Blue_104
218
MN
Nov 9, 2004
  • Nov 9, 2004
Hey, Im in the same place right now. I guess that in order to clear the codes you have to be doing a scan and cancel the scan in progress. Supposidly youre not supposed to diconnect the battery to clear the codes because when you hook it back up, a battery fault code will be stored.
The last way to clear the code is to let the car go through 3 warm up cycles (engine going from cold to running temp), as long as the problem doesnt happen in those 3 cycles, on the fourth start up the engine light will go off.
hope that helps, no one likes that damn yellow light.
SpectorV
1,872
Florence, Alabama
Nov 10, 2004
  • Nov 10, 2004
remove the negative battery terminal and then letit sit a couple min. after taping the brake to drain any power remaining in the system. the light WILL go off after you reconnect it but... it may not stay off if it stays off more than 10 min you sould be good.
97WhiteStang
43
Vienna, VA
Nov 16, 2004
  • Nov 16, 2004
hey thanks guys, i just borrowed my friends scanner and cleared the codes but its good to know what i need to do next time....
thanks,
Jake
A
A/F ratio gauge install questions.
  • AngryH58
  • Thursday at 1:10 PM
1996 - 2004 SN95 Mustang -General/Talk- Thursday at 2:25 PM
squeak93
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
