check engine light
  • Thread starter Thread starter BAD91LX
  • Start date Start date Oct 28, 2009
BAD91LX
1,186
9
48
Hurricane, Utah
Oct 28, 2009
  • Oct 28, 2009
Ok, I have an issue with the 91 lx 5.0 I just picked up. The check engine light keeps coming on and I had a smog pretest done the other day and the NOX levels where high. The check engine light only comes on after the car runs for a bit. Do you think it's the O2 sensors or the cats themselves. I need to get this thing smogged and registered quick and I have to take it to a smog only center.
strtrcr50
Previously from Dirty Jerzey exit 7a
Oct 28, 2009
  • Oct 28, 2009
High NOX indicates a problem with the EGR system. Most likely you either have a problem with the vacuum lines to the egr valve, the solenoid that feeds vacuum to the EGR, or the EGR valve itself. Try searching for user JRicker and egr as the search term. He has an excellent diagnosis document. Pull codes and report back.
BAD91LX
1,186
9
48
Hurricane, Utah
Oct 28, 2009
  • Oct 28, 2009
Will do thanks!
BAD91LX
1,186
9
48
Hurricane, Utah
Oct 28, 2009
  • Oct 28, 2009
Not finding anything by JRicker
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,118
224
Massachusetts
Oct 28, 2009
  • Oct 28, 2009
It's "JRichker"
Don't assume anything. Run the CEL codes. Either go to Autozone and do it, or search how to do it here. That will tell you exectly what the computer doesn't like
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 28, 2009
  • Oct 28, 2009
High NO - high combustion temps - retard timing, check EGR for operation.
High CO – Rich condition - fuel pressure too high, check O2 sensors, replace air filter, Clean MAF element.
High HC – Lean misfire, vacuum leak, common misfire due to worn or weak ignition system components. On rare occasions, an overly rich mixture may be the cause. Do the ethanol/E85 fill up as suggested.
High CO & HC - Cat converters, smog pump, and smog pump controls.
How to pass emissions testing:
1.) Make sure all the emissions gear the car was made with is present and connected up properly. That includes a working smog pump and cats. The smog tech will do a visual check to make sure that all the original equipment is present and connected up.
2.) Make sure that you have fresh tune up with spark plugs, plug wires, cap, rotor, fuel & air filters. An oil & filter change is a good idea while you are at it.
3.) Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
4.) Post the codes and get help to fix them. Don’t try to pass with codes not fixed. Clearing the computer just temporarily removes them from memory, it doesn’t fix the problem that caused the code to be set.
5.) Be sure to do the testing on a hot engine. Drive for 15-20 minutes prior to taking the test to get operating temps up into the normal range. Do not shut off the engine while waiting for your turn on the test machine. An engine up to full operating temperature puts out fewer emissions.
BAD91LX
1,186
9
48
Hurricane, Utah
Oct 28, 2009
  • Oct 28, 2009
Hey, I appreciate all the help! I plan on giving it a fresh tune up and clean up the intake this weekend. Oil change and all! The check engine light doesn't come on for about 10 minutes of running the car. My level of no was around 1434 everything else was below average.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
