Check Engine ?
  • Thread starter Thread starter 9890Mustang
  • Start date Start date Jul 25, 2005
9
9890Mustang
11
Miami,FL
Jul 25, 2005
  • Jul 25, 2005
Ok I have the check engine light on in my car . And the code for an " inlet air solenoid vavle " showed up and I would like to know what this is where is it ? please help I'm going crazy!!!
HISSIN50
34
129
Jul 25, 2005
  • Jul 25, 2005
What was the code number? And year of stang?
9
9890Mustang
11
Miami,FL
Jul 25, 2005
  • Jul 25, 2005
year 90 code 81
vristang
4,933
101
124
Seattle
Jul 25, 2005
  • Jul 25, 2005
Don't remember the actual translation from "code 81" to English, but pull the IAS and clean it with throttle body cleaner. You will find it on the throttle body. It is the cylinder on the side of the TB.
HISSIN50
34
129
Jul 25, 2005
  • Jul 25, 2005
seems to me that for an 5.0L, 81 is a secondary smog diverter code. It is part of the emissions system.
MeanMussy
581
Louisville, KY
Jul 25, 2005
  • Jul 25, 2005
code translation
http://www.corral.net/eec/
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 26, 2005
  • Jul 26, 2005
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
See http://http://www.veryuseful.com/mustang/tech/engine/images/88Stang5.0Vacuum.gif for help on the vacuum line plumbing.
MeanMussy
581
Louisville, KY
Jul 26, 2005
  • Jul 26, 2005
broken link...
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 26, 2005
  • Jul 26, 2005
MeanMussy said:
broken link...
Fixed the link, thanks for the heads up
amplifier28
222
#10
  • Jul 26, 2005
  • #10
Link to vacuum line plumbing image is still broken!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 26, 2005
#11
  • Jul 26, 2005
  • #11
Try this one...
The website seems to be having problems, try again later.
9
9890Mustang
11
Miami,FL
Jul 27, 2005
#12
  • Jul 27, 2005
  • #12
thanks the info =)
9
9890Mustang
11
Miami,FL
Jul 27, 2005
#13
  • Jul 27, 2005
  • #13
I have been doing some reading and found out that 81 is IAS circuit failure =(
HISSIN50
34
129
Jul 27, 2005
#14
  • Jul 27, 2005
  • #14
I dont think you have one of those (that is for the 3.0L motor).
But you did not provide info on what the issue actually is (what the car is doing) so we are all just helping as much as we can.
9
9890Mustang
11
Miami,FL
Jul 27, 2005
#15
  • Jul 27, 2005
  • #15
I looked up what icode 81 means in the Chiltons book. The cars performance is crappy and it idels up and down . Thanks again for all your help =)
9
9890Mustang
11
Miami,FL
Jul 27, 2005
#16
  • Jul 27, 2005
  • #16
I have 2 other codes that come up 82 & 66 . I had someone tell me they think I have a grounded wire in my wire harness. =(
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 27, 2005
#17
  • Jul 27, 2005
  • #17
Code 82 – Secondary Air Injection Diverter Solenoid failure AM1. The dump valve air diverter valve (front vacuum operated valve) isn’t working on the Thermactor Air System (smog pump). Look for broken or missing vacuum lines on the solenoid valve to the diverter valve Check the solenoid valve for +12 volts at the Red wire and look for the Red/White wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the Red/White wire for the solenoid valve
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
9
9890Mustang
11
Miami,FL
Jul 27, 2005
#18
  • Jul 27, 2005
  • #18
Thanks Im going to check all of this out tommorow after work and I well let you how it turns out.Thanks for all your time =)
9
9890Mustang
11
Miami,FL
Jul 30, 2005
#19
  • Jul 30, 2005
  • #19
lol I finally found out whats wrong with the car. The flow meter!!! =)
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 30, 2005
#20
  • Jul 30, 2005
  • #20
I'm guessing you mean the MAF...
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
