Check Oil Light After Oil Change
GrandmasterK
874
Madison, WI
I changed the oil on my 1989 5.0 a few days ago and after about a half hour of driving, the check oil light came on. I checked the oil then and again later once the engine was cool and it looks fine. The oil pressure looks normal too but the light still stays on...
I've driving about another 20 minutes since then but it makes me really nervous given that I just had the engine rebuilt last summer, I need this engine to last me another decade or two :)
Any thoughts on why the light might be on?
Could be an issue with the sensor, or the wire got pulled off/damaged. Can you crawl under and have a look at the wire?
If you pull the dipstick and see it is full, I wouldn't worry too much. The check oil light is just the level sensor in the pan. I do not believe the oil pressure switch is tied to it at all.
