Checking crankshaft end play
  • Thread starter Thread starter gnx547
  • Start date Start date Jan 8, 2013
gnx547
283
  • Jan 8, 2013
I want to check crankshaft end play and wondering which area in the crank do I insert the feeler gauge? And what size feeler gauge should go in?
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Jan 9, 2013
  • Jan 9, 2013
use a dial indicator on the snout of the crank and rock the crank back and forth with a pry bar
gnx547
283
  • Jan 9, 2013
I borrowed my friends dial indicator and I only have .002 of crankshaft end play. What can I do to increase the end play?
gearheadboy
1,425
177
84
Greencastle Pa
Jan 9, 2013
  • Jan 9, 2013
Is the crank new or used? New bearings I suppose? Just curious. And if everything is ok and you are checking it correctly, you can remove the bearing and sand it on a flat surface with 1500 grit sand paper with oil.
gnx547
283
  • Jan 9, 2013
It is a oem used crank and the journals are polished and bearings are new. How many bearings do I sand? Just 1 of them?
gearheadboy
1,425
177
84
Greencastle Pa
Jan 10, 2013
  • Jan 10, 2013
The thrust bearing and only on the sides. Search google.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jan 11, 2013
  • Jan 11, 2013
The crank thrust bearing is the one in the center journal, BTW.
That's total play if you pry back and forth, right?
gnx547
283
  • Jan 11, 2013
Do I sand both thrust bearings? The one in the block and in the main cap? And sand both sides of the bearing?
blacksheep-1
322
Jan 11, 2013
  • Jan 11, 2013
Hold on a minute! unbolt the thrust bearing cap, rock the crank back and forth, then bolt the cap on and incrementally torque it down, while you're doing that rock the crank back and forth as you tighten it. This will align the thrust bearing, you may have more play than you think.
gnx547
283
#10
  • Jan 11, 2013
  • #10
When I unbolt the thrust bearing cap, do I also unbolt the other caps?
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
